Forum
Welcome Guest
Show/Hide Header
Welcome Guest, posting in this forum requires registration.
Pages: 1 [2]
Author Topic: Marking your material
DLT_Andrew
Permalink
DLT_Andrew
Post Re: Marking your material
on: February 15, 2013, 13:47
Quote
Sharpies will leech into vinyl and bleed through permanently damaging the vinyl.
-Andrew
Guest
Permalink
on: September 4, 2014, 15:54
Quote
Great thread. We work 95% on leather and have been using the Stabilo glass marking pencils, both white and blue, after a reco from a pinstriper. They're water soluable and the markings come off fairly easily with water as long as you don't press too hard when marking. If the markings get a little stubborn, some leather cleaner will remove them. Only issue with them is that the point is soft and breaks now and then if too much pressure applied.
We just ordered some Fisher silver ink pens, based on the reviews here and elsewhere, and looking forward to trying them.
JBBowling
Permalink
JBBowling
on: September 4, 2014, 20:51
Quote
Fischer space pens all the way. write on all colors. from white all the way to black and will stay on until wipe away with soap and water or any decent interior cleaner. you can get them from amazon but i get them from my supplier snowden supply. chris snowden is a great dude and i think he gets them at a better price than amazon or ebay.
Guest
Permalink
on: September 4, 2014, 22:23
Quote
Thanks for the tip JBB!
hot rod-
trimmer
Permalink
hot rod trimmer
on: September 19, 2014, 11:18
Quote
I spotted a chevy roadster at a hot rod show that was trimmed in white vinyl and where the sun had been on it you could see all the measurements that the trimmer had written on the back that had bled through as he or she had use a ball point pen !!!!!!!!! A BIG NO NO !!
Gtrimming
Permalink
Gtrimming
on: September 19, 2014, 18:20
Quote
Quote from hot rod trimmer on September 19, 2014, 11:18
I remember years ago one of the lads did a embroidery job on a rolls front head rest, he put a big L and R and the foams in permanent marker pen ( for some reason) a few years latter the car come back and the permanent ink had gone through the scrim and leather!
martythetr-
immer
Permalink
martythetrimmer
on: September 22, 2014, 02:12
Quote
as a result of reading this thread I just bought my Fischer pens from Snowden supply....impressed with how well they mark, also with the clean off....great service from Chris and at a far better price than I can buy them for here in Australia!
Lairds-
Customs
Permalink
Lairds Customs
on: September 23, 2014, 14:05
Quote
hey all check out Ward and Kennedy. http://www.ward-kennedy.com/ProductCatalog.aspx?ClassID=3&SubClassID=15&CategoryID=70&selection=2 They have the silver ink pens for $2.66 which is cheaper then the space pen refills. The ink is exactly the same as the fisher/space pens but at much lower cost. The only difference is that the space pen is pressurised better so youll get every last bit of ink out of them. I've been using their regular silver ink pens for about 10 years and couldn't be happier with them.
Steve
Permalink
Steve
on: September 23, 2014, 15:32
Quote
I get mine from Ward and Kennedy also.
Guest
Permalink
on: September 25, 2014, 20:38
Quote
Update: I'm liking the silver ink pens. Only issue is that they don't work well at all on smooth grained leather, as was mentioned previously in this thread.
Penfold
Permalink
Penfold
on: January 31, 2015, 21:00
Quote
Old thread update.
I use these white water erasable pens all the time on darker vinyl and leather,wipes off nicely with a damp cloth although it does seem to leave a slight residue which I'm not sure is visible when dry so only use on areas that can't be seen when finished, great for stitch lines, ie diamond stitching.
http://www.ebay.co.uk/itm/Fabric-Marker-Washable-Pen-BLUE-or-WHITE-/201257695756?pt=UK_Crafts_Sewing_Supplies_MJ&var=500454885513&hash=item2edbe4ba0c
Guest
Permalink
on: February 1, 2015, 03:00
Quote
I would like to try the space pens. Are they all the same or is there a special one. They don't spicify washable.
trimacar
Permalink
trimacar
on: February 3, 2015, 12:35
Quote
I don't usually sew vinyl, and rarely a top stitch seam, so when a good friend asked that I sew some covers for his Model A hot rod, I had the same issue...how to mark for a top stitch.
Not knowing any better, I thought, well, he wants a 2 inch spacing, so why not mark with tape?
Using 2 inch painter tape (the blue stuff), I laid it straight on the material and backing and sewed along each side. I then put tape down for each additional stitch, but always measured from the first stitch in multiples of 2 inches, that kept them all straight. It's fairly easy to follow the edge of the tape, and even if you catch a small piece of it it'll pull right out.
Kind of an off the wall solution, but it worked!
Lairds-
Customs
Permalink
Lairds Customs
on: February 6, 2015, 18:03
Quote
I have used tape to hold Velcro or listings/pulls on the back side to hold them in place. I never considered using it as a guide on the top. That may be worth a try, thanks trimacar.
Another slightly odd way of marking I'll use often is a construction chalk line for marking pleats. Position and snap 2 or 3 times, re-chalk the line then position and snap. Though I wouldn't use colored chalk with white thread. Try to use a chalk that's similar to your thread color.
Bodnar720
Permalink
Bodnar720
on: March 29, 2015, 08:17
Quote
Office Depot makes a water soluble fine tip pen that works great! Only 6 bucks.
Darth
Permalink
on: February 1, 2017, 22:07
Quote
Are the Fisher Space Pens in black just as good as the silver ones.
redstrat
Permalink
redstrat
on: February 5, 2017, 13:32
Quote
Just to chime in, I have also used Stabilo pencils for years without problems. They are water soluble, come in many colors and sharpen to a nice point. http://www.dickblick.com/products/stabilo-all-colored-marking-pencils/
Naseem-
Muaddi
Administrator
Permalink
Naseem Muaddi
on: February 7, 2017, 00:17
Quote
Hey Darth. Please fill out your profile. Thanks
12amrider
Permalink
12amrider
on: February 16, 2017, 04:12
Quote
I found refillable chalk markers at fabric and craft stores that are good for laying out top stitching. you can get different colors of chalk. on vinyl wipe with a damp cloth, on cloth an air nozzle blown on the stiches. run one down the edge of a straight-edge the width of your pleat and you have a chalk line 1/16 in. wide that is erasable.
VB
Permalink
VB
on: February 17, 2017, 16:47
Quote
My $.02 there is no best thing for marking on fabric. Space pens are great, chalk markers also, I’ve used crayons, pencil and sharpies. With sharpies use black I can’t remember if it is red or blue but one of those colors never really dries. Depending on the material what works best all depends on the fabric / material that is being used. With that said some writing tools with leech through or stain the material so always test and have many options at your disposal.
wizardry19-
69
Permalink
on: February 22, 2017, 22:31
Quote
I use chinagraph pencil on vinyl and kids chalk on cloth.
Warm water and baby shampoo cleans thr vinyl up and air for the chalk.
Pages: 1 [2]
Mingle Forum by cartpauj
Version: 1.0.34 ; Page loaded in: 0.253 seconds.
